Old 25th February 2010, 09:24 PM
steve8274 steve8274 is offline
Default sump dimensions
hi
i have a 1.8 cvh sierra engine and in process of doing head gasket. i understand the sump has to be altered for clearance.
does anyone have any diagrams / measurements of what is required. and how much do you take off pick up tube
thanks for any help
steve
Old 25th February 2010, 09:47 PM
The sump has to be made about 150 mm high, from the gasket to the bottom.
One practical way to do it is to flip it upside down on a level surface, fix a pencil on a square and use it to mark the 150 mm waterline. Then cut and extenend the sump on the shallow side or to the side to make up for the lost volume.
Ideally, you want the bottom of the sump at the same height as the bottom of the bell housing. My rough measurement with a tape measure indicates it's about 155 mm with a Type 9.
Hi Steve
When I altered the CVH sump for the engine I was going to use, it only needed 20 -25mm removing from the bottom.
You should be able to follow the general guide in the book
If you take 20mm from the sump, take the same amount from the pick up pipe.
If you look at the sump when the engine is bolted to the gearbox .... You'll notice that the sump is not a great deal lower than the bottom of the gearbox bell housing .... You'll not gain a huge advantage by removing too much sump
