Old 27th February 2010, 07:48 PM
onedayTM onedayTM is offline
Default rear upright assembly.
hi guys,
quick question about producing rear upright. How far does RU7 go inside RU5.as on page 70 in the bottom dimension drawing it looks like it goes all the way in but in the drawing at the top thats not the case.
cheers,
tony.
Old 27th February 2010, 09:22 PM
On that diagram RU7 is drawn as 3 mm plate, whereas it should be 10 mm, it's on the list of amendments. It must be flush with the edge of the tube.
Old 27th February 2010, 09:52 PM
PM sent to you Tony
Sorry I called you Mike Senior moment on my part
Old 28th February 2010, 08:10 PM
cheers albert and to you ronnie for that info I'll need to look at that in more detail now.
tony.
