Old 6th March 2010, 01:40 PM
geeman's Avatar
geeman geeman is offline
Default Identify Wires
Hi, i have a 1.8 carb cvh, but have no idea about the fiord wiring, as i have no recollection when i took the sierra apart. I know these wires go to the lternator,battery and starter, but where and how? I hope to have the engine running an a few hours!!!
my build pics
geeman's Avatar
my build pics
Old 6th March 2010, 02:00 PM
1 - Goes to the alternator, they are keyed and ponly fit one way.
2 - Goes to the Battery + terminal
3 - Big terminal onto the free big termina on the starter, Black and red to the starter solenoid. ( 3rd I am unsure of, whats at the other end? )
Old 6th March 2010, 02:04 PM
geeman's Avatar
Thanks, any idea about 4 and 5. Will hopefully have a video of it running up today or tomorrow
my build pics
4- Big red one to the battery +12.
4- Black one looks like an earth I think, where does it go?
5- Brown earth on battery, red +12 on battery. Black I think this is an earth and joins to the earth on the starter cable.??
Old 6th March 2010, 02:07 PM
geeman's Avatar
oh yeah, should have said, the red in 3 goes to the read in 4, and the black in 3 goes to the square one in 4, if it helps. ALso where do they go? i have never doen anything with ford engines beofre, so really have no idea as to what im doing
never mind, im too slow, youve already replied. THanks
my build pics
Old 6th March 2010, 02:37 PM
DaddyA's Avatar
DaddyA DaddyA is offline
Hi Geeman hopefully i can help,
just been having the same problem with mine(should of took more photos).
3 - red goes to starter solenoid,
- black / red goes to starter solenoid,
- black negative lead put to one of the starter motor securing bolts.
4 - red to +12v
- black lead in background to to -12v
- other black lead attached to eng block (I used the lifting point bolt).
5 - put to +12v (supply hazards and fuses?).
Note - I'd add a couple of earth leads from you engine to chassis as well, just to be on the safe side.
Hope that helps, I've now got a problem with my ignition solenoid - Think i was a bit heavy handed with the pliers!!!!!
Daz...
Old 6th March 2010, 02:46 PM
geeman's Avatar
OK, its turning over now, now for the stupid question, how do i connect the ignition coils?? im confused, as i cant see what 2 thing to connect to each other. On the engine, what do i connect the coils to as i can find any connectors?
my build pics
Old 6th March 2010, 03:44 PM
What engine are you using, and what have you done with the engine loom?
Old 6th March 2010, 03:48 PM
From your pics, your using a 1.8 CVH, so you should have the loom with the ESC-Hybrid ignition module. On this you will find the coil negative plug.
The coil +12v plug is part of the front body loom and not the engine loom ( I haver no idea why they did this )
