Old 7th April 2010, 03:43 AM
Tim Taylor Tim Taylor is offline
Default Front Upright Caster
I have put the front together and find that with the upper wishbone installed (long arm forward) and eccentric mushroom in place (hole forward) the upper/lower balljoints are not aligned vertically. There appears to be maybe 7 to 8 degrees positive (rearward) caster.
Is this about right?
Old 7th April 2010, 08:18 AM
teun teun is offline
Yes this is right. otherwise the steer wouldn't come back in the middel after a turn.
