Old 8th April 2010, 04:10 PM
The Ssssnake's Avatar
The Ssssnake The Ssssnake is offline
Default P Clips
Hi all
Has anybody got a rough idea of how many p clips are required for running brake/fuel lines (Is there a max. distance between clips) I have noticed you can get double stacked clips as well which look like a push to fit to chassis from car builder solutions. Are these IVA approved or would I be better off sticking with the rubber lined p clips and rivets?
Cheers Jake
Old 8th April 2010, 07:09 PM
Originally Posted by The Ssssnake View Post
Hi all
Cheers Jake
The push in ones are much cheaper here. I don't know if they are iva safe or not.
Old 8th April 2010, 07:21 PM
geeman's Avatar
geeman geeman is offline
the ones i used are nylon p clips from maplin, they are cheap and i think they should be fine for iva. they are sold in packs of 100 which is enough as i still have a quite a few left over.
my build pics
Old 8th April 2010, 10:55 PM
i used plastic maplin ones for the brake pipes electrics and fuel lines, went through iva without a mention.
Old 8th April 2010, 11:10 PM
Mainstream use push on, so should be fine
Old 9th April 2010, 01:05 AM
tkpm tkpm is offline
What size P clips are used 6.4 or 3.2
Old 9th April 2010, 06:35 AM
These are great p clips tk:
http://www.cbsonline.co.uk/stainless...5ss-1482-p.asp
not very cheap but when i took mine for sva the examiner commented straight away how well they looked, just helps to get you off to a good start.
AndyH
Old 9th April 2010, 08:41 AM
[quote=tkpm;35831]What size P clips are used 6.4 or 3.2[/QUOTE
6.4 for brake lines from memory.
Old 9th April 2010, 08:46 AM
geeman's Avatar
and 9.5 for fuel lines, and a mix of the 2 sizes for electrics
my build pics
Old 9th April 2010, 08:53 AM
Spud
I'm not tight but they seem mighty pricey!! Might just go down the mild steel route at half the price.
How mant do you reckon you got through completely?
