Old 7th January 2008, 11:35 AM
bobbyh bobbyh is offline
Default chassie tests
do ou know wat test will be done on the chassis at the test and can i have them or do them befor hand to make shoure it passes ?? thanks
Old 7th January 2008, 08:14 PM
Chris Gibbs
The SVA test?
If so, the only test is a visual one. If your welding looks ok in the places that the tester can see then you should be fine. They don't do any dismantling or torsion testing.
Hope this helps
Chris
Old 7th January 2008, 10:05 PM
oh cool thnaks
