Old 29th January 2008, 12:03 PM
murpia murpia is offline
Default SVA requirements for steering column
What are the SVA requirements for the steering column?
Reason being I was thinking of fabricating my own column arrangement rather than using donor parts. I know it's supposed to be 'collapsable' but what does that mean in terms of load etc. required to collapse? And how far?
Regards, Ian
Old 29th January 2008, 12:31 PM
jabs jabs is offline
This from the SVA manual
Old 29th January 2008, 12:37 PM
Chris Gibbs
These pictures might help too
All in all I think it would be difficult to meet the requirements with a home made column, but nothing is impossible.
Chris
Old 29th January 2008, 01:19 PM
Fig. 1 of the offset joints type was what I had in mind.
Is there a minimum angle or offset specified?
Thanks, Ian
Old 29th January 2008, 01:50 PM
Chris Gibbs
It's a minimum of 10 degrees, and as the SVA manual says "it is unlikely that joints of this type will work at angles above 30 degrees"
So it's between 10 and 30 degrees.
Chris
Old 31st January 2008, 12:02 PM
CurlyBen CurlyBen is offline
One option might be to have the steering column as two tubes, one with an ID slightly greater than the OD of the other and drilling a hole through the pair and linking them with a shear pin of some kind. obviously you need to make sure it's not going to shear with steering forces! I've got an idea that would alleviate that problem but it starts making things too complicated. I think the above is essentially what's being done to the F750 car I work on, but we're buying it and I've yet to see it. We've also got a prop shaft at a hideous angle, probably over 30 degrees, and that's caused one failure so far! It'll also sap power and feel..
Old 31st January 2008, 10:44 PM
macdave69 macdave69 is offline
Daft Question
But why would you want to build your own column, ?
Old 3rd February 2008, 01:06 AM
colt_mivec colt_mivec is offline
Originally Posted by macdave69 View Post
Daft Question
Depends on the build,What engine,Clearances etc.
You need to modify and change things to keep in the SVA regs but make it work for yourself and your build
Old 3rd February 2008, 01:45 AM
Nope still don't get it
Old 3rd February 2008, 02:02 PM
Chris Gibbs
I'd be wary of the shear pin idea to be honest, you could design it for normal steering loads but then it might fail under additional load such as kerbing or large pot holes.
If you were to design it with these loads in mind then you run the risk of it not shearing in an accident.
It's feasable to design your own steering column but given the inconvenience and possible SVA pitfalls I think you're better using a production car item.
Chris
