Hi,
I've got a twin cam Sierra that I was going to use as a kit car donor but due to many other commitments and projects i'm now unable to find the time. 2.0 Twin cam engine. Auto box although I have several 2wd MT75 gearbox's and associated parts eg props / pedals etc available Other than that car is complete. Just out of MOT and Tax but was used daily as a run about and everythings ok. May want the odd bush renewing and the rear shocks are knackered. I also have a massive supply of Sierra spares available so if theres anything that you want just let me know. Pinto bike carb conversions, MT75 / T9 propshafts / diffs etc etc I'm happy to sell the car complete for £300 as it is or break it up for parts if people need the front assemblys / rears / hubs / rack / diff etc. I can deliver parts if required, I am up and down the M1 corridor regually and I also have a flat bed to deliver the car if required at a cost of £1.50 per mile (only charge the outgoing journey, not the return milage). Either reply on here or email me at doughnutters@hotmail.com Cheers ![]() |
I am after an MT75 box, how much?
Cheers.
Failed builder
Don't suppose you have the rubber inner gear lever gaitor do you?
Enoch |
Assuming its just a 2wd twin cam MT75 box then its £60
2wd MT75 hybrids for the 24v Cosworth engine are a fair bit more. I have all the bits to build 2 of these but none ready to go at the moment. |
I'll have a look and take some pictures later for you if I have ![]() |
Im after some steering column shroud? Do you have a picture, as I have 2 of the wrong kind already
http://www.flickr.com/photos/3326151...7611049241239/ |
There are several different types of surround for the steering coloumn dependant on yera. Mk1, Mk2 and facelift Mk2 ones.
I think I have at least one of each in the loft / shed or garage, which type is it your after? |
The one im looking for, came from a G reg, 2.0DOHC Giha, I have the bottom half, just need the top half and hazzard switch. I can take a picture if it is still needs explaining
Cheers, Jas
Failed builder
I'm based in Derby but can get goods to Northampton and Watford areas on a regular basis ![]() |
| Thread Tools | |
| Display Modes | |
