Old 9th August 2010, 06:36 PM
carlknight1982's Avatar
Default 17" wheels
Anyone see any problems with running 17" wheels? obvoiusly wingstays would have to be modified, would the saturn arches cope andys?
also would the IVA man kick up
Carl
Roadster No 2 build
Cost to Date : £93
Old 10th August 2010, 04:17 PM
It all depends on what profile tyres you fit!
Big wheels with low profile tyres could be smaller that small wheels with high profile tyres.
You can get tyre size calculators all over the internet, in fact most on line tyre retailers have them.
Old 11th August 2010, 09:08 AM
tex tex is offline
too big - they will be heavy - try 14 or 15 max. 13 is good but limited tyres. the heavier they are it affects unsprung weight
Old 11th August 2010, 10:50 AM
Gtta be 15 minimum for my rear uprights as on discs,
Roadster No 2 build
Cost to Date : £93
Old 11th August 2010, 01:11 PM
LOL I can tell you haven't built a roadster then! You need 15" wheels to clear the rear suspension arms. 13" and 14" wheels are a no go. If everyone was fanatic about unsprung weight you'd have aluminium brake calipers and magnesium wheels. Its not really an issue for a car that weighs around 600 kgs.
Also as Mr Henderson correctly pointed out, 17" wheels just mean you'll have some stupidly expensive low profile tyres on, to correct the rolling circumference of the wheel. To highlight the point, my 15" Toyo tyres were £28 each. 17" tyres to give the same profile are £70 each.
