Old 20th August 2010, 10:43 AM
piston head piston head is offline
Default newbie needs help
Good day! I'm new at forum!I live in Latvia,where kit car building thing not so popular!I got Chris Gibbs book and get obsessed I have few questions about spare parts:
1)Drag-link ends from transit-year,number?
2)Is it possible to use lower balljoints from different car maker(not Austin)?
P.S.-sorry for mistakes
Old 20th August 2010, 12:14 PM
Welcome to the forum.
Good question for which I do not have the answer to hand.
It has been discussed before, the conclusion is that it's the only one suitable due to the way the suspension damper load is transmitted to the lower wishbone rather than through the suspension strut as in the sierra donor.
Old 20th August 2010, 02:19 PM
mopple mopple is offline
Hi piston head. I'm from Estonia. Also there is a member named alga, who is from Lithuania.
The answer to your question is in this post http://www.haynes.co.uk/forums/showp...68&postcount=1.
As for Maxi ball joints. I found that for me it was cheaper to order them from Saturn Sports Cars from UK, than from local motor factors. All info about Maxi ball joint part numbers from different manufactures is also in the referred post.
So if you have any more questions just ask, as there is lots of knowledge info in this forum. Also try to use forum search, as most of things are already discussed.
With best regards
Madis
Old 20th August 2010, 08:24 PM
Thanks for info mopple and twinturbo
Old 20th August 2010, 10:48 PM
Hi piston head. I got the ball joint pack from EDS, http://cgi.ebay.co.uk/330462019865 . It cost me around €72 with shipping, which I think is a fair price for 6 joints.
Some people here in Lithuania use some Opel lower ball joints (apparently, from Vectra A/ Astra F). That requires adapting the lower wishbone design for the Opel joint, however apparently fits into the Sierra upright without modification:
