Old 27th September 2010, 10:12 PM
Snowy Snowy is offline
Default Chassis Steel
Hi everybody,
After reading the book for a couple of times and reading kit car magazines for ages i have decided its about time i started building my own car.
I am starting this weekend but need to get the steel ordered this week so it will be delivered before the end of the week.
I spoke with a couple of local steel stockholders and they said i can get rolled steel 25x25mm square section with 2, 2.5 & 3mm wall thicknesses OR 25x25mm ERW tube with a 1.2, 1.5 & 2mm wall thickness. Any ideas which wall thickness i should go for or what you have used?
All help or advise would be great, think i may be needing plenty of it over the next few months/years!!
Thanks
Old 27th September 2010, 10:19 PM
james3004's Avatar
ERW with a 1.5 or 2mm wall
Welcome to the forum
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 27th September 2010, 10:20 PM
Andy J Andy J is offline
2 mm is the norm you could order a flat pack kit from HandyAndy all the cuts are done for you
Old 27th September 2010, 10:24 PM
Out of interest what is the difference between ERW and rolled steel tube?
I am tempted by the flat pack kits to save time but have the use of my dads workshop with bandsaw so will try and save a bit of money where i can.
Thanks for the help.
Old 27th September 2010, 10:56 PM
The book specifies 1.6 tube (16 gauge). By moving from 1.5 to 2.0 wall thickness you get a 21% decrease of beam deflection for a 30% increase in weight.
Old 28th September 2010, 09:38 AM
David_17's Avatar
David_17 David_17 is offline
Another local. Welcome along.
I would reccommend a flat pack kit off Handy Andy
*updated 7/6/11*
Old 28th September 2010, 01:01 PM
If your in north Yorks then take a trip over to Saturn to see them, Handy should be able to show you what's involved in the flatpack.
Old 28th September 2010, 01:09 PM
Just spoke to Snowy (James) on the phone TT, good bloke and is going to come over one Saturday for a monkey burger and blast out......
Cheers....AndyH
Old 28th September 2010, 01:17 PM
Excelent.
Don't poison him
Old 28th September 2010, 09:17 PM
big_wasa's Avatar
big_wasa big_wasa is offline
2mm is to thick you want the 1.5mm or 16swg
Nowt again.
