Old 2nd November 2010, 01:21 PM
JHewitt's Avatar
JHewitt JHewitt is offline
Default Any good?
Looked at this deal on the bay a few times, seems a good deal, but has anyone here bought these, and can give a good/bad review? or of course suggest an alernative?
Joe.
http://cgi.ebay.co.uk/Front-Hub-Join...item5add1e19dc
Old 2nd November 2010, 01:37 PM
Joe.
Thats a good price for all three Joe, cheaper than i can get them trade from Rally Designs.
AndyH
Old 2nd November 2010, 02:52 PM
Need Sierra TRE though not Escort ones.
Old 2nd November 2010, 03:49 PM
Ordered my set last week on the Wednesday, had them ready to fit on the Friday. It was the cheapest place I could find, better than any of the autofactors we deal with.
Escort RS2000 (Mk2 Escort) TRE fit fine. Plenty of people have used them, and I know SSC sell them for use on the roadster.
Old 2nd November 2010, 04:35 PM
MikeB MikeB is offline
Seem to remember I bought RS2000 TRE from rally design last time round and they didn't fit had to swap them for Sierra ones. I may be going mad.
Mike
Old 2nd November 2010, 04:53 PM
The RS2000 track rod ends fit the Escort Mk2 rack, metric threads, if you try a Mk1 rack rack they have the imperial threads which they will not fit.
You should be okay......AndyH
Old 2nd November 2010, 05:04 PM
JHewitt's Avatar
Default ok
Cheers guys, so they will fit, no they won't , yes they will, no they won't, yes they will.
Think I will go for it, then and as long as I get the mk2 escort rack I will be ok.
Old 3rd November 2010, 08:53 PM
Trophy Blue's Avatar
Trophy Blue Trophy Blue is offline
It really irritate3s me when they describe RS2000 track rod ends. There is no difference between a 1100L TRE and a RS2000 TRE. As far as I know, all metric TRE's will fit ie. Escort, Cortina, Sierra's all the same tapers, threads etc
Old 3rd November 2010, 10:51 PM
On the Sierra rod ends the axis of the rod is is not centered on the ball, it is shifted forwards about 5 mm. Escort rod ends are symmetrical. Also, Sierra rod ends have a triangular protrusion that might cause a radius issue.
Old 6th December 2010, 10:04 PM
gaz05 gaz05 is offline
I bought the EDS saver pack and it doesn't fit. Spoke to EDS and it would appear these are for Cortina and Capri uprights. The TRE taper is way too small for the taper hole in my diesel Sierra uprights. The drag link doesn't go all the way through the 3GE mushrooms to allow a full nut on. I can't ream them out either because the rubber is already up against the top of the mushroom. It might work if I get the mushrooms turned down a bit more but non access to a lathe was the reason I bought them in the first place.
It never rains but it bloody pours.
Total cost so far
Materials £3,150
Tools £855
