Old 18th November 2010, 06:34 PM
John.W John.W is offline
Default 2.0 Doner
I have just collected my doner, a very tidy 2.0 EFI pinto with 165000Km on the clock and a service history all the way to 140000. The engine runs like a dream the only problem I have found is a small oil leak around the rocker cover.
Old 20th November 2010, 07:57 AM
picy is too small to see but all the old pinto leaked a bit around the rocker.
its the way the rockercover and gasket is designed me thinks nothing to worry about
Old 20th November 2010, 03:16 PM
Most leak all over the place due to lack of maintenance on the breather.
Same goes for a lot of engines, breathers are often overlooked.
Old 20th November 2010, 11:02 PM
I was trying to make the photo bigger but I was told it was too big I will try again
Old 21st November 2010, 07:12 PM
Pinto engines are very prone to leaking arround the rocker cover.
They use a cork gasket & are often over / incorrectly tightened
Fit a new gasket & all should be well
Old 21st November 2010, 07:32 PM
yep, probably about 14LBft will do, which is just nipped up. Any more and you crush the gasket and risk warping the rocker cover.
Old 23rd November 2010, 10:20 PM
I hope this works this time here are the pics of my donor
