Old 19th January 2011, 09:51 AM
axle's Avatar
axle axle is offline
Default Engraved chassis plate
Hi
Any idea where I can get the above?
Regards Axle
Old 19th January 2011, 12:56 PM
fabbyglass
I'm sure someone on here has a set of letter and number stamps who could punch out a wee bit of plate for you for cost of postage if nowt else
Old 19th January 2011, 01:25 PM
jiwillia jiwillia is offline
AXLE,
Blank plate from http://www.vin-plate.co.uk/ and stamp data yourself or get local trophy shop to engrave it.
John
Old 19th January 2011, 02:23 PM
carlknight1982's Avatar
Ebay...............
Roadster No 2 build
Cost to Date : £93
Old 19th January 2011, 02:28 PM
Deanno's Avatar
Deanno Deanno is offline
http://www.kitpartsdirect.com/page19.htm
This company use to sell them on eBay but no longer do. they are advetised in Complete kit car magazine.
I think they are about £12 and they even list the haynes roadster.
Hope this helps
Dean
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 19th January 2011, 03:56 PM
davidimurray's Avatar
When I did my actual chassis plate, I got a bit of 3mm steel plate which I then CNC machined the number into it and welded to the chassis. Remember that the actual chassis number must be permanently affixed to part of the car so the riveted on ones would not be acceptable.
Old 20th January 2011, 04:48 PM
Tony Tony is offline
I was wondering about this, I do MSVA as I build trikes, but for MSVA we cant use a plate, the number has to be stamped into the actual frame.
a set of stamps are easy and cheap.
my advice is to practice, but the way I do it is to have a bit of angle iron clamped down as a guide so they all sit in a neat row, in a straightline, also remember to strike it once and properly.
Old 20th January 2011, 07:09 PM
I think there should be both -- VIN stamped into the chassis and a riveted plate under the bonnet stating various data such as VIN, manufacturer, gross weight, etc.
Old 20th January 2011, 08:30 PM
You are right Albert,it also needs the axle weights on it.
VIN and manufactures plate.
Old 24th January 2011, 04:31 PM
axle's Avatar
Thumbs up
Hi All
Thank you to all of you for your inputs!!!!!
Regards Axle
