Old 31st May 2011, 08:52 AM
Default Daytime Running Lights.
So are these now mandatory on Class "M" Self builds?
Old 31st May 2011, 09:21 AM
eSteve's Avatar
eSteve eSteve is offline
Default Day Light Running Lamps (DLRs) optional
TT,
Day light running lamps (DLRs) are optional.
This is the appropriate snippit from the IVA manual:
Regards,
eSteve
Old 31st May 2011, 05:31 PM
What about in the latest manual, new production cars now have to have them ( as of a couple of months back )
Old 31st May 2011, 08:13 PM
eSteve's Avatar
Default Snippet is latest...
TT,
the snippet is from the latest IVA manual, which I downloaded today.
See my post:http://www.haynes.co.uk/forums/showp...8&postcount=10
The version/date on the snippet is not the current manual's version and date, since the section the snippet has been taken from has not been updated since its rev. 3 29/6/2009.
Since it maybe a couple of years until I submit my build for IVA, I intend to fit them, (I have a pair in the garage and have included the necessary wiring on my wiring diagram) as I suspect they will become mandetory in the near future.
OT: Did you see my questions for you in this post?http://www.haynes.co.uk/forums/showp...0&postcount=15
Regards,
eSteve
Old 31st May 2011, 09:12 PM
i believe as of next year they will need to be fitted to all kits. its no big deal at the end of the day. all it requires is an extra 12volt feed to the front
Old 1st June 2011, 06:06 PM
Can't you just run the Dipped Beams?
Old 1st June 2011, 09:48 PM
In short the answer is no,they only work on the front.
Note 6 states they must turn off with the headlamps/or dips.
The fine for improper use of lights is a £1,000 max ie :fog lights when not needed in daylight.
Old 2nd June 2011, 11:09 AM
cornishmaid cornishmaid is offline
Is this for newly built vehicles only or would older cars have to abide by these new rules for the MOT?
Built February 2009 using Mx5 components.
Old 2nd June 2011, 03:52 PM
There is nothing in section one of the testing guide to do with day running lights of any type and the only mention is made to class 5 end marker lights.
Old 6th February 2013, 08:07 AM
loony's Avatar
loony loony is offline
Is anyone here using DRL with built-in indicators ?
Something like this (but E-marked): http://www.ebay.co.uk/itm/LED-DRL-Daytime-Running-Lights-Turn-Signal-Indicators-UNIVERSAL-8LED-15-5cm-/150874551162?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item2320d2f37a
I was thinking that this could be good option to have LED DRLs (especially in BEC) and LED indicators... placed under/in front of headlamp brackets.
Lucas
ZX9R BEC Haynes Roadster - build cost so far: £1125
My build thread
"Whatever you can do or dream you can, begin it. Boldness has genius, power, and magic in it." J.W.Goethe
