Old 16th June 2011, 10:27 AM
misty misty is offline
Default wires
Hi All
Working on the wiring at the minute
On the column there are switches with wires coming out,,, on the loom i have matched up the same wires but what is the best way to join them together, would i pull out the wires from the switch and replace with the new wires or just bare the wires on both and twist solder and heatshrink the join .
Old 16th June 2011, 01:04 PM
You could put terminals on if you need to remove it again.
Old 16th June 2011, 01:07 PM
good thinking i will go and do that now
many thanks
