Old 31st July 2011, 06:49 PM
Danb1987 Danb1987 is offline
Default Checking diffs...
I came across 2 diffs yesterday when I fetched all my stuff but is there a way of seeing what car there from? I know there sierra but one is for push in shafts and one is for bolt on shafts...
Pic Small one on the left big one on the right
Built is so much better than Brought!
Old 31st July 2011, 08:05 PM
xBooglex xBooglex is offline
Push in type is 7" and bolt on is 7.5" and won't fit the standard chassis mounts as I've just discovered!!
No such thing as a problem just an opportunity!!
Old 1st August 2011, 10:05 AM
spalders spalders is offline
Hi Just going through the same process and came across this site in a previous thread. www.super7thheaven.co.uk I've a 7.5 and have just discovered that the brackets and bolt hole spacing are different. Luckily I've not yet welded the brackets so should be able to sort it ok.
Old 1st August 2011, 05:28 PM
the larger diff looks like the type i have fitted from a scorpio.
I made the brackets as per the book as i recall.
