Old 7th August 2011, 10:56 AM
old_bill old_bill is offline
Default scuttle scratches
I've just skinned the scuttle with aluminium and being a bit ham fisted have made a few scratches . My question is what's the best way to polish then out and leave a nice shiny finish?
Thanks in advance
Bill
http://www.flickr.com/photos/old_bill/
Old 7th August 2011, 01:48 PM
You will have to use a metal polishing compound.Best bet maybe would be to try something specifically for polishing mag wheels as it would probably be the least harsh.
Old 7th August 2011, 02:15 PM
MarkB MarkB is offline
autosol is not bad stuff but there is bound to be some fancy soap that polishers use, try Frost's who do car restoration goodies
Old 7th August 2011, 05:07 PM
If you manage to polish out the scratches and make it all shiney you might want to to give it a few coats of clear 2K over the top, when it gets wet it will have what looks like milk stains all over it.
Old 9th August 2011, 05:02 PM
autosol? if its not to deep but then you will need to do the lot to mirror finish
Old 9th August 2011, 07:47 PM
Thanks for the tips guys
Bill
Old 11th August 2011, 07:46 PM
If the scratches are deep you can take them out with 1200 wet and dry providing that the gel coat is deep enough and then polish. On the last kit i built i grabbed a small tub of gelcoat from the guy that did the laminating , most useful for damaged edges etc.
Old 11th August 2011, 07:58 PM
He is talking about an ally skin Rob,dont want to pee on the bonfire guys but I had a converstaion with another builder on this very subject and we agreed in the end that on a sunny day the reflection would be blinding.
If you want to coat it with laquer it may help to use something like plastic primer/adhesion promoter otherwise the laquer may not stick.
Good luck
Old 11th August 2011, 09:27 PM
I know its well ott but if funds ever allowed i would be guilty of this
http://www.madabout-kitcars.com/imag...-006-id125.jpg
That alloy body is pure automotive porn. I think i could cope with having to where shades.
Old 11th August 2011, 10:21 PM
Tis rather tasty........
