Old 4th September 2011, 12:07 PM
brainbug007's Avatar
Default Starter Motor Connections
Can anyone post a pic of how the starter motor gets wired up? I've got what I think is the right part of the loom with a thick black, thick red, and a smaller red & black wire with a nut stuck on the end but I can't work out which way round they onto the starter motor.
Old 4th September 2011, 05:50 PM
I've taken a picture of how I think it goes, can anyone confirm i've done this right?
Old 4th September 2011, 05:53 PM
rpjg1975 rpjg1975 is offline
That looks to be right from memory. Pics are on my laptop though to be certain. Sure someone will confirm shortly though
Russ
Old 4th September 2011, 07:27 PM
that is not right
im pritty sure the balck thick one goes to starter mount bolt and is the main neg bond or "earth"
its needs sorting before the battery gets conected if i was you
Old 4th September 2011, 07:28 PM
Surely that black isnt right.
Does the contact that the black is on not come live when the solenoid if energised, so there should be a wire from this contact to the starter motor its self?
I would have thought the black would have gone on a bolts on the housing as the engine/ gearbox should be earthed.
Am i making sense?
Old 4th September 2011, 07:30 PM
Originally Posted by baz-r View Post
that is not right
Snap...... lol
Battery due for a big bang if not sorted.
Old 4th September 2011, 07:33 PM
AS per other post, thick back goes to gearbox ( although starter mount bolt should do fine )
Old 4th September 2011, 08:22 PM
Defo big bang theory,if you look carefully there should be a braided lead from the terminal you have the black lead on and that feeds the starter when the solenoid is pulled in.
The black lead is earth.
Old 5th September 2011, 09:00 AM
Just shows how little I know about electrics So in this picture, the black wire (circled red) goes onto one of the gearbox bolts? Are the positions of the thick red wire (circled yellow), and small red/black wire (circled blue) correct?
Then for the battery connections in this picture, the medium thickness black wire that comes from the negative terminal (circled red) should be bolted to the chassis and I remove the small wire going from the chassis to gearbox (circled blue)? Or should the wire go from chassis bolt to head (blue circled one)?
Old 5th September 2011, 11:41 AM
Just to echo what other people have said. The heavy black earth cable should be to the engine block / gearbox. The heavy red one (permanent live) is in the correct location. The lighter gauge red/black looks like your Ignition switch which should go to where you had the black one.
You should really get a multimeter on these things and trace all your wiring. The way you had this, you would have done some harm, backfeeding the ignition barrel with the battery live. I think you'll also have your alternator going onto the live as well.
