Fiberglass
I was just wondering if anyone has attempted making their own bodywork? I'd love to give a go and learn how to work with fiberglass but I'm worried about the cost side of being a false economy in that by the time I've messed a few bits up it would have worked out much cheaper to just buy it? any able to give me an idea roughly what sort of quantities of materials you need to make say the scuttle, a wing, an nosecone? the book seems to indicate that the materials are cheap if bought in bulk?
It is not just a case of making a panel. You need to make a buck, then take a mould from the buck, to then make the panel you require from the mould.
After playing around with modifying my dash panel with fibreglass it is a very messy / smelly job, and I would not want to have a go at making panels
http://s831.photobucket.com/user/dav...ter%20Pictures OTR 01/05/14 - 1.6 CVH, Type 9, Bike Carbs, Megajolt |
Ya I know it would take ages, it was more if i could save myself a few hundred quid it might be worth it as a set from saturn is nearly £600 delivered
At the end of the day its whatever is best for your own build, some people have made their own bucks and bodywork to good results. AndyH
Haynes Roadster / Saturn GRP Bodywork. Now available direct through http://www.gillhamonline.co.uk/ or contact me direct on andrew.hugill@ntlworld.com Regards..........AndyH |
So time aside though, what would the cost of materials be roughly?
About a third of the cost - more with VAT added, if you where making bucks then quite a lot more.
Please dont think i'm trying to put you off though it's just the question was asked.... AndyH
So would it just be 450g chopped strand matting, a colored polyester resin, a catalyst that I would need ignoring anything for the buck? If so how many meter's of matting and liters of resin would you recommend for say a scuttle?
450g csm matt: 3m Gel Coat: 1/2 litre Resin: 2 litres Catalyst: 60ml plus ancilliaries. AndyH
Thanks Andy this helps Is there a good way to work out how many meters of csm you need for a wing and the nosecone? And would you say the ratio's mentioned here are about right? http://www.cfsnet.co.uk/acatalog/met...uantities.html
Thread Tools | |
Display Modes | |
