Old 24th September 2011, 07:27 AM
Matthew Matthew is offline
Default Wanted - Brake Pressure Reducing Valve
Hi
Has anyone got one of the standard brake pressure reducing valves they don't want?
I've got discs all around and need something to reduce the rear line pressure.
Thanks
Matt
Old 24th September 2011, 09:13 AM
Scrappy,vauxhall corsa and most fords have them either in the cylinder or at the rear pipes.
Old 24th September 2011, 10:52 AM
Are they the straight pressure reducing valves, or the deceleration sensitive ones?
Old 24th September 2011, 03:22 PM
rapidtornado's Avatar
try get one off MK2 fiesta, there's a link on locostbuilders, that's what I've bought cost me a tenner bolts straight into master cylinder... don't know if it will work but it's been used a lot on robin hood set-ups with discs all round
Old 25th September 2011, 11:30 AM
Late reply,pressure reducing personally I would avoid anything speed sensitive as it would be for a larger heavier car and possibly a problem.
Old 25th September 2011, 01:23 PM
Trophy Blue's Avatar
Trophy Blue Trophy Blue is offline
Fiat Uno ones are available from factors very cheaply, they can be made adjustable very easily, made unadjustable for IVA, and then returned to the original state!
Old 25th September 2011, 02:09 PM
kj71 kj71 is offline
If its the ford sierra deceleration valve i have one you can have.
Old 25th September 2011, 06:41 PM
Thanks. I've PM'd you with my contact details - let me know what you want for it.
Matt
Old 25th September 2011, 06:53 PM
I bought one of those (from Brakeparts, part #HRV1013), but I can't work out what I would need to do to make it work correctly - do you have the details?
That's why I was looking for the standard Sierra one - as far as I can tell it just shuts off the rear brakes when the decelleration reaches a certain rate. It may not be optimal, but seems from comments that as long as it is mounted identically to the Sierra then it is enough to pass the IVA.
Matt
Old 26th September 2011, 12:02 PM
Roller brake tester does not take into account deceleration only brake effort/force so could cause a fail at test/IVA.
