Old 26th September 2011, 08:17 PM
Default 2 Aluminium fuel tanks 4 sale
Hi guys....I have made a couple of long range fuel tanks mainly to practice my TIG skills which I am glad to say are fine......ok the tanks ...I have made them with the saturn rear tub in mind so the angles follow that, they are made from 2mm aluminium and have a single baffle in the centre, they both have a surge tank welded to the bottom right of the tank looking from the rear, fill point and one vent and fuel return again on the right. Capacity is 8.2 gallons..... one minor stumbling block is the location of the surge tank will mean the relocation of the CP8 which is not too difficult....one has a turned cap with o ring ...one open for a rubber pipe.....here are a few photo's.......looking for £100 + p&p....each
Old 29th September 2011, 01:34 PM
Cannot believe these have not gone....I thought I'd have my arms ripped off.
Ok....this will be the only reduction before they go onto the LCB site £80 +p&p
so I would guess £85 posted....these tanks are Ally,baffled,sumped and shaped for the haynes roadster howay man
Old 29th September 2011, 02:00 PM
MikeB MikeB is offline
Wasn't there a group buy on tanks a couple of weeks back?
These look go though, I want a longer shallower one to keep the boot space for weekend camping trips otherwise I would have ripped your arm off at that price!
Old 29th September 2011, 03:05 PM
Can do you a shallow one if you want.... £75 posted same height as the top of the diff cage.....the group buy was for mild steel ones, drop me a pm if interested
Old 29th September 2011, 05:44 PM
Sure Adrian.....just give me a shout when you want one.
Old 1st October 2011, 09:59 AM
Am looking for a 2.9 escort mk2 steering rack if any one fancies a swap for one of the tanks
Old 2nd October 2011, 12:05 PM
jmh jmh is offline
Hi there,
I am interested in one of the tanks.
Can you tell me the height of the main body of the tank please?
Also, presumably the tank that you are going to use will be similar, I was wondering what fuel level sensor you are using (is it the sierra one?)
Cheers,
Jonathan
Old 2nd October 2011, 03:49 PM
Hi Jonathan both tanks are 310mm high ....360mm to top of filler....I am undecided as to which tank I intend to use so still unsure as to which sender to get ...I may just get a universal one from ebay (around £24 with differing float lengths) One thing I am sure of is I am installing a long range tank as I don't want to be "sweating it out" trying to locate a fuel station, I also have another tank in the fabrication stage that has a 12gallon capacity. Both of the above tanks are up for grabs.....they have been pressure tested and there are no leaks.
yes all the tanks are at least 310mm high and yes the one I use will be as well
just drop me a pm if you want one.
Old 8th October 2011, 12:37 AM
One of the tanks now gone (the one with the turned cap).....other one is still available if any one wants a cheap Ally/sumped/baffled tank.
Old 8th October 2011, 11:06 PM
Do you fancy using your TIG to produce one for the mx5 sender? The ones you have built so far look really good!
