Old 27th December 2011, 08:02 PM
Default anti theft!
hey all, im a little confused to what is acceptable as anti theft... i have had a little search and learnt a tiny bit but nothing clear.
my scenario:
i dont have an ignition lock and barrell on my sierra column but i will be having a seperate ignition switch and a batt cut off, is this acceptable or will i have to fit an electronic immobiliser?
thaughts?
Michael
Old 27th December 2011, 08:47 PM
From my reading of the IVA manual you need either a steering lock, or an electronic immobiliser.
It specifically says a manual battery switch is not considered an anti-theft device, so yes I think you will need an electronic immobiliser (unless you find a new column with the barrel / key intact).
Old 27th December 2011, 10:06 PM
Thank you i was more biased to getting an immobiliser anyway might get a transponder type , thatll do the trick
Old 28th December 2011, 03:25 AM
Default The latest is here, Butt Print Recognition. No Joke!
http://www.aol.com/video/protecting-...c1_lnk2|123128
Old 28th December 2011, 09:49 AM
Butt Print technology, they've got to be having a laugh.
It MIGHT make it into some specialized vehicles but the first person that fits it to a kitcar should be shot as a warning for others.
Old 28th December 2011, 10:30 AM
I dont think I could be arsed with that
Old 28th December 2011, 01:39 PM
Make sure you have a certificate for the fitting of the imobiliserthey may want to see it.
Old 28th December 2011, 01:45 PM
the good book says
1.
A vehicle MUST be fitted with either a mechanical anti – theft device or an electronic immobiliser
2.
If fitted to the Vehicle, a anti – theft device
a.
must be operational
b.
must not operate on any part of the braking system
3.
If it incorporates a mechanical part that acts upon a system used to control the vehicle
a.
It must Deactivate before the engine can be started
b.
It must be deactivated while the engine is running
c.
It must have a actuation which is a distinct and separate function from that of stopping the engine
Where the vehicle has no mechanical anti - theft device fitted:
4.
An electronic immobiliser must be fitted
Old 28th December 2011, 10:07 PM
Wish mine didnt have a bleeding immobilizer tried to fire it all up yesterday got fuel but no spark ! Paperclip test and i get three codes
Secondary air pump failure
Another insignificant one
AND the good old immobilizer control unit failure ( no signal)
Bugger ! All seems to point to cam sensor supposedly quite common !
Still pi$$ed on my chips
Old 28th December 2011, 10:18 PM
i see! is your's a vauxhall system? because mine will be and im kind of running myself into great difficulty if it goes wrong as techincially im using 2 transponder systems. ie the factory ecu barrell (with the transponder secured to it) and then a thatcham type immobiliser I certainly hope all goes well!
