Old 23rd January 2012, 08:43 PM
superleggo superleggo is offline
Angry Zetec ECU EEC-V
School boy error
Hi folks
I think I have made a schoolboy error.
I am trying to get a Zetec to run on its original ECU with PATS using a ECC-V ecu. Form info on it looks like it can be done which is the good news. However when I obtained me 2.0ltr black top engine (Engine code NGD...) I go the keys and transponder ring but not the Dash module.
After spending the day with the wiring loom and wiring diagram it looks like I am missing the vital part, the instrument cluster. Am I right in thinking that the instrument cluster contains the Instrument Control Module (ICM) and the ECU nees a feed from this to run?
Also is the ICM coded to the ECU/PATS so I need the instrument cluster from the same car as the ECU?
What does the ICM look like? Is it embedded in the instrument cluster?
I was also told that you need the Generic control module (GCM) What is this as I can not see it on the wiring diagram.
Any help more than welcome.
Old 23rd January 2012, 10:06 PM
try www.fordpower.org.uk
Generaly getting PATs working is considered a MASSIVE struggle.
Old 26th January 2012, 06:16 PM
big_wasa's Avatar
big_wasa big_wasa is offline
Pats is not hard its four wires.
Whats the code name on the ecu ? for a blacktop upto atleast 1999 you dont need the dash.
Ive done several from 92 pre pats eec-iv upto 99/2000 eec-v's
this is running on a 97 eec-v and has some obd2 functions.
http://youtu.be/BKqeCjdBM0w
A little pats demo for you
http://youtu.be/pUbV0NPvx4M
This is a 99 ecu that I wired for a guy. It is only a test and doesnt idle as it should as most of the sensors where sat on the car and not in the engine ....
Nowt again.
Old 27th January 2012, 05:44 PM
Would you care to PM me the details, will be useful for my 95 Mondeo V6 Engine and my Blacktop.
