Old 26th February 2012, 04:23 PM
Default saturn dash bottom edge?
does the bottom edge of a saturn dash comply with iva regs or do i need to extend mine.
it has a radius but finishs at 90deg in a J fasion
Old 26th February 2012, 04:45 PM
shh120m's Avatar
shh120m shh120m is offline
It needs edge trimming, and the passenger side will need boxing in for iva.
Old 27th February 2012, 09:49 AM
I was unsure about the bottom edge of the dash so I extended it into a full 180 degree radius. Also the center section of the dash did not meet with the top of the transmission tunnel so I extended that at the same time.
Boxing in the underside of the passenger side is not necessary for IVA. Gus didn't on his. All they made him do was add a piece of rubber U-trim to the return lip on the scuttle as it overhung the top rail.
Old 27th February 2012, 07:02 PM
shh120m's Avatar
depends, if there is wiring under there
Old 27th February 2012, 07:34 PM
Gus did have wiring but it was neatly wrapped so not likely to get caught by a passenger
