Old 8th March 2012, 07:44 PM
shh120m's Avatar
shh120m shh120m is offline
Default Anybody know p clip distances
Does anyone know off the top of their heads the minimum distances for fixing fuel hoses/ brake hoses and wiring in the tranny tunnel for IVA?. I know its in their somewhere but for the life of me I cant find it. Reason I ask is i think ive truly overdone it and ive run out of rubber lined p-clips, being a tight arse i was going to remove a few and carry on
Old 8th March 2012, 07:50 PM
Every 100 mm from memory
Old 8th March 2012, 09:58 PM
Dont say 100 mm ! If it is im bolxxxx !
Old 8th March 2012, 10:06 PM
Me too!
I thought it was every 150mm?
Old 9th March 2012, 12:06 AM
I thought it was 100mm in the transmission tunnel, and 150mm everywhere else? Can't really go wrong if you secure it too often.
Old 9th March 2012, 12:20 AM
Eternal Eternal is offline
Im going 100mm all over just to be on the safe side.
Skyline Roadster
Old 12th March 2012, 08:06 PM
Thats me b***oxed as well then...
I'm sure its no more than 150mm in tranny tunnel and 300mm everywhere else..
Found this by Spud
Hi David,
The manual says that all cables / pipes must be securely fitted at a max 300mm intervals and free from chafing. This reduces in the tranny tunnel though and needs to be every 150mm, preferably laid on a channel.
AndyH
Old 12th March 2012, 08:40 PM
its says. (in genral construction)
"All electrical cables/wires must be free from chaffing and secured at intervals of at least every 300mm unless contained in a secure hollow component."
cant find anything with an actual mesurement at the mo for brake and fuel pipes but i cant see why the trans tunnel would be any diffrent from the floor,rear axel area or engine bay.
i dont think any production car has clip spacing as tight as 100mm (4in)
Old 13th March 2012, 05:05 PM
snapper snapper is offline
300mm
I did mine closer than that but just made sure it looked tidy and was no more than 300 anywhere
Old 19th March 2012, 09:17 PM
Hi,
So is this issue resolved and what is the final outcome.... Need to know if I have got to drill more holes..LOL
