Old 4th April 2012, 08:13 PM
Default small question on switch setup
Hey all, do you reckon I will be able to get away with having a main "key lock"IE a separte dash mounted ignition barrel, to operate a live feed then a flick switch for fuel pump and a flick switch for ignition then an engine start button? will mr iva not like this?
any info or experiences will be appreciated
michael
Old 4th April 2012, 08:46 PM
Why not a dash mounted key switch similar to a standard car one with off-acc-run then a separate start button. I wouldn't like the fuel pump on a switch incase it got turned off by mistake
Old 4th April 2012, 09:01 PM
Column Lock acts as one of the imobalisers that are required for IVA. Keeping it saves other hassle.
Old 4th April 2012, 09:39 PM
balls! because I am going to have to remove mine from the column due to not having the key.
i might search for new barrell but its just money id rather spend on other stuffs haha
Old 4th April 2012, 09:40 PM
You dont have to use it, but it's an easy one.
Old 4th April 2012, 09:58 PM
ideally id like as i said earlier with an electronic immobiliser maybe, or maybe im over engineering this , what do you reckon?
Old 4th April 2012, 10:02 PM
Replace the barrel.
Old 4th April 2012, 10:04 PM
Ring a few auto lock smiths, see if they have a Ford TIBB barrel decoder. And if so take your column along and they will read the lock and supply a new key.
Old 4th April 2012, 10:50 PM
You can buy a new ignition lock and barrel on ebay for less than 15quid.
