Old 12th April 2012, 01:39 PM
Peter-C Peter-C is offline
Default Electrical quickie
Should the fuel gauge work with the battery connected but no key in the ignition. I am using the original sierra instruments and sender.
Cheers Peter
Old 12th April 2012, 02:04 PM
My fuel gauge works without the key in the ignition,
I,ve used the original Sierra instrument binnicle but with an aftermarket sender unit.
Old 12th April 2012, 02:06 PM
Cheers Andy
Old 12th April 2012, 02:08 PM
Hi Peter
The Original Sierra fuel gauge remembers its last reading when the ignition is turned off.
For example, if you have 1/4 tank of fuel, the gauge will still read this after the ignition is turned off.
Hope this helps
Old 12th April 2012, 02:33 PM
brainbug007's Avatar
Sorry to hijack this thread but what you said reminded me of something I meant to ask about bonzo. For some reason my gauge/sender (orginal sierra ones) only gives a reading from 1/4 to full tank but won't go below a 1/4 even when the arm is all the way at the empty position?
Old 12th April 2012, 04:51 PM
Pull the wire off the tank sender unit and if the gauge goes to empty the problem lies with the sender unit.
Old 12th April 2012, 05:32 PM
When I put fuel in yesterday the gauge went up to about 3/8 full. Today I had disconnected the battery live and when reconnected gauge went back to where it was.
Hope that makes sense.
