Old 30th May 2012, 09:53 PM
mgglep's Avatar
mgglep mgglep is offline
Default Bonnet
Hi everyone on the Saturn bodywork am I right in assuming the Saturn bonnet wide bulge is 1metre long so the gap between scuttle should be 1010mm thanks in advance
My Build pics
Old 30th May 2012, 09:54 PM
mgglep's Avatar
Sorry I mean gap between scuttle and nose cone
My Build pics
Old 30th May 2012, 10:01 PM
shh120m's Avatar
shh120m shh120m is offline
Its excactly the same legnth as the standard bonnet, fogive me for not knowing off the top of my head, il measure it up in the morning and post it up. As long as the scuttle is in the correct position and the nose is tight up against the front frame it will fit
Old 30th May 2012, 11:32 PM
mgglep's Avatar
Cheers Nathen the scuttle meets the bend in the chassis doesn't it cabin side
My Build pics
Old 31st May 2012, 08:46 AM
shh120m's Avatar
yes thats correct, you sometimes need to trim the bonnet to get an exact fit, depending on what size edge trim your using.
Old 31st May 2012, 09:41 AM
mgglep's Avatar
thanks alot
My Build pics
