			 There are lots good, informative posts on the forum that get lost in banter.  The usual way to address this problem is to have an FAQ thread/post with links to the most informative theads.  The way to do it is to have a sticky thread with an edited first post, and people suggesting questions and links to the FAQ in the thread.  So, I'm volunteering to maintain the FAQ.
			Here are my first ideas ideas about what questions should go in, I'll edit to fill in links and more questions. How much steel do I need for the chassis? In short: most people nowadays go for HandyAndy's flatpack kit. No measuring and cutting, perfect angles and dimensions everywhere, like a Lego set you have to weld together. If you want to do it yourself, though, get 7x 6m lengths of 25x25 and 3x 6m lengths of 20x20. There will be some leftovers but you'll be glad you have them. http://www.haynes.co.uk/forums/showthread.php?t=6263 http://www.haynes.co.uk/forums/showthread.php?t=6553 http://www.haynes.co.uk/forums/showthread.php?t=6377 http://www.haynes.co.uk/forums/showp...56&postcount=3 http://www.haynes.co.uk/forums/showp...9&postcount=44 http://www.haynes.co.uk/forums/showt...6733#post46733 Where do I get steel for chassis, and what should I ask for? Steel type and online suppliers Steel types Steel grade 1.5mm frame thickness What's RHS, ERW, CDS? (thread: Welding required) What welder should I get? Buying a welder FAQ What is the weight of the complete chassis? Weight of finished chassis? chassis weight What's the size and weight of the finished Roadster? The length of a Roadster with ali rear tub and Saturn nose cone is ~330 cm. The widest point is at the rear arches, 169 cm with aluminium side panels. The wheelbase is around 238 cm (Sierra: 2608 mm), track width ~145 cm with standard wheels. Size of a finished Roadster?? Weight of Roadster? What's the average weight of a finished Roadster? Total weight of the car How many kgs? Weights of Sierra components What are the dimensions of the GRP bodywork panels? Fabbyglass aka Triton, Saturn aka SSC, NTS and Gillham Online used the same molds as they changed hands. Apart from these there are GRP parts made from other molds by Equinox, there are panels made by AGM sports cars, and there are panels as in the book provided by MK Engineering. We have the drawings for Triton/Saturn/Gillham panels and for the ones supplied by Equinox: Bonnet drawing (Saturn Price Squeeze and developments) SSC Scuttle drawings Reload this Page Equinox Bodywork measurements in 3D What is the recommended suspension setup? Chassis and suspension set up info request spud69's setup (thread: still confused about arms) What shock absorbers should I get? shocking question? What shocks? shock length How much does a typical build cost? Build cost Where does CP24 go? Between BR1 and BR8 (and BR2 and BR9), under the suspension bracket. Where can I get Haynes Roadster parts? Parts Suppliers Thread - Who Sells What & How to Get Hold of Them We got f*** by Darren George Bits for the build you forgot about Are there CAD drawings of Roadster chassis and parts? 3d cad (Fabrun's Solidworks BMW-based roadster drawing) Solidworks chassis model by mopple Also, there is a 3d model of the bodywork parts obtained by putting Saturn bodywork into an industrial 3d scanner, PM Hoybi for a copy. AutoCad chassis, plates for laser cutting (thread: I thought I'd seen something about cad files of the chassis, but can't find anything) cad.zip Also, here is a nice drawing of the chassis: http://www.soudeur.com/photographies...ueschassis.pdf Front upright mushroom insterts (mushrooms) Where do I get a manifold for bike carbs? You make them How do I go about wiring? David Murray's wiring diagram How do I fill in the IVA forms? IVA Application Form IVA 1C Forms for DVLA after IVA. Please suggest questions with answers!
			Albert Haynes Roadster FAQ | Haynes Builder Locations Gallery, build thread in Lithuanian / via Google Translate. Last edited by alga : 25th June 2017 at 08:27 PM.  |
			 Nice one Alga....defo good for a sticky
			 This is a brilliant idea. It will save new members having to spend hours searching for the important stuff they need.
			 Brilliant idea
			 Any help, Albert? - http://www.haynes.co.uk/forums/showthread.php?t=7367
			 albert
			i found this website while browsing earlier. all to do with the zetec engines. might come in handy to someone. http://www.toyne.org.uk/zetec.html and got a pdf version of the IVA manual too. http://www.businesslink.gov.uk/Trans...ion_Manual.pdf hope it helps Last edited by martinl : 2nd June 2012 at 07:22 PM.  |
			 Great idea Albert
	  I,ll make this thread into a sticky , & also once the intial "good idea" posts have been made, I,ll delete them & keep the content of the thread to INFORMATION ONLY As its your thread Albert, would that be ok with you ? cheers andy  |
			 Nice one Alga, good to see this.
			 Banter is great, but loosing the rare gold nuggets in it is a pity.  Hence this thread!
	Albert Haynes Roadster FAQ | Haynes Builder Locations Gallery, build thread in Lithuanian / via Google Translate.  |
| Thread Tools | |
| Display Modes | |
