Old 9th June 2012, 01:22 PM
james3004's Avatar
Default Alternator Wiring
Went to the local scrappy today and got a nice little alternator off of a Honda CRX
The only problem is i can't quite work out the terminal connections on it!
They are labeled on the sticker
Obviously the post goes to the alternator
IG - ignition live?
L - Live ?
FR - ?????
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 9th June 2012, 02:12 PM
Wynand's Avatar
Wynand Wynand is offline
Here is the wiring for Honda using the 4pin Denso
L = Ignition lamp
IG - for Ignition switch protected by15A fuse
C - goes to computer then back out to ELD (Electric Load protector)
B - (recharge wire) goes to battery protected by 15A fuse
FR -goes to computer.
the numbers on alternator plug should be ;
1 = C
2 = IG
3 = L
4 = FR
Hopefully this can give you a basic idea, but since you do not have the Honda wiring on your ride, perhaps these Denso schematics applicable to Toyota can help in a vague way...
Just use the wires needed to connect to function, no need for the computer crap as per Honda.
Wynand
http://5psi.net
Old 9th June 2012, 05:09 PM
Note that Honda engines turn counterclockwise, so the fan inside the alternator will run opposite to its intended direction. It might not be too much of a problem. I got a Hitachi alternator off a Nissan though.
Old 9th June 2012, 06:11 PM
james3004's Avatar
thanks for that guys as for the fan we'll just have to see what happens
--- James ---
Flickr Album
Old 9th June 2012, 11:09 PM
I have a book here with all the plug layouts. The unmarked terminal on your picture is to the battery and shown as S a charge sensing wire, really important this one it stops the alternator cooking the battery . FR according to this book is field rectified, god knows what thats used for.
Old 10th June 2012, 03:46 PM
be careful with nippon alternators when shopping as there are some that are wired up a bit odd and need a relay to make them work .
nothing that cant be worked around but worth paying attension
Old 11th June 2012, 01:33 AM
Today it took me an hour or two to get my Hitachi alternator off a Nissan Sunny to charge. I even took it apart again to look for some obvious failures.
Apart from the charge cable, it's got two wires going out of it: L (dashboard charge light) and S (sense, ignition +). I hooked up the wires, but no voltage appeared on the BAT pin. I almost declared it dead, but tried switching the wires around. BAM! 43 volts on output! Turns out, I connected the dashboard light has to ground instead of the ignition +, that prevented the alternator from charging.
