Old 15th June 2012, 11:06 PM
tkpm tkpm is offline
Default Pinto Engine Loom
Hi Guy's
Have just started fitting my wiring.
But i have a few problems.
One of my problem is.
My sierra donor was originally fitted with 1.8 cvh, at some point it had a 2l pinto fitted.
The cvh engine loom was hacked about to fit the pinto, i was wondering if anyone had a proper pinto engine loom they didn't need in exchange for beer tokens.
The next problem is i've lost all my pictures i took while disconnecting the electric from my donor , so remembering what went where is going to be a bit tricky .
So i will be posting up some pictures and asking what is meant to be attached to this and that.
A big thanks in advance for any help that i my get.
Terry
Old 17th June 2012, 11:11 PM
Most pintos where wired up quiet basic so should not be to hard to get it all sorted
Did you not go for a new loom come the end?
Old 17th June 2012, 11:23 PM
Hi Baz,
no didn't get one, but the way things are looking i my have to go that way.
the loom i've got, was from injection engine and it was hacked about quite badly.
Terry
Old 18th June 2012, 11:07 AM
What have you actualy got?
A sierra 2.0 Pinot (carb) model should be runnign an ESC-2 spark control, the 1.8 CVH will have had a ESC-Hybrid. Or is this a PRE-Sierra 2.0 running Points?
Old 18th June 2012, 05:03 PM
I'm running a, 2L Pinto with weber twin 40's with a electronic dizzy.
Terry
Old 18th June 2012, 06:07 PM
Who's dizzy? The ford one or an aftermarket one?
Old 18th June 2012, 06:24 PM
It's the ford one, will post up some pic's later tt.
Old 18th June 2012, 06:26 PM
You will need the ESC-2 module to go with it then, as well as the loom.
Old 20th June 2012, 08:22 PM
sorry about the delay in pic's,
is this ESC-2 you was on about TT,
carbs
dizzy
coil
coil wires, does it matter which way round they go on the coil.
Old 20th June 2012, 08:26 PM
Ahh, my mistake it runs basic TFI not ESC ( my poor memory ).
But yes that module is your ignition amp.
