Old 25th June 2012, 09:45 PM
BenBrooks BenBrooks is offline
Default progress progress progress
finally managed to get some pics up after faffing about with reducing the file size. what a nightmare. anyway, in case anyone is interested I'm most of my way through welding up the chassis and got to the flipping stage yesterday which was quite a big jump for me. just a few more welds to do then grinding done some others and touching them up a bit.
shouldn't be too long before i get some running gear in!
Old 25th June 2012, 10:32 PM
Looking good
Tip: Weld a few tags around before painting to use for earthing engine and other stuff .Its easier to cut them off if not needed than to mop up the tears as you grind your lovely paint off to weld bits on--Dont ask how I know
Old 25th June 2012, 10:42 PM
cheers ayjay i never would have thought of that, great idea.
Old 26th June 2012, 09:44 AM
MikeB MikeB is offline
upload your pictures to flickr and paste the link here, no issues them with filesize and resizing.
Old 26th June 2012, 12:25 PM
Looking great Ben
Keep the progress pics coming, & as Mike says, use either Flickr or photobucket to make uploading photos easier .
Just a quick question...which engine are you using/installing ? as you may find depending on engine choice you might have to remove TR5 as it gets in the way of the carb inlet ,
Old 26th June 2012, 01:02 PM
i'm setting up a flickr page now, took me ages to work out the link think but seems so obvious now.
Andy: I'm 90% sure i'll be using a k series 1.8 as i have an mg zr lying around. i will do a trial fit of all the running gear before i paint the chassis though so if there are problems with tr5 i can just cut it out.
Ben
Old 26th June 2012, 01:27 PM
after i very stupid 10 minutes i've worked out flickr. some clearer pictures for you (though they aren't very large, haven't figured that one out yet)
Old 26th June 2012, 03:49 PM
It would look much better outside. But you'd need someone to help you carry it out for a photo shoot
Old 26th June 2012, 06:46 PM
well it will have to come out soon to be blasted and painted so i'll get better pictures then
