Old 20th July 2012, 10:12 AM
Default Diff
Picture of the beemer diff I am using
Speedo output in the back case <kin handy>
Rear mount
108mm flanges
Easy mountings.
Old 20th July 2012, 09:30 PM
That looks a big old lump
Old 20th July 2012, 09:48 PM
If that has 108mm CV joints then it's not that much bigger than a 7" sierra/granny diff. I like the simple bolt pattern on the front is the lug with the slot on the back for a securing nut or some thing else?
Old 21st July 2012, 12:04 AM
Afron its big but a good bit smaller than the salisbury jag/tvr unit. Its also a lot easier to mount. Its small enough to drop out through the bottom of the rear frame but the big plus is its bomb proof with plenty of choice on the ratio front.
Phil, the front lugs will require a mod on sb4 and cp10, that will let the nose of the diff into the gear tunnel and keep the driveshafts in line. Other than that its not a bad unit.
Old 21st July 2012, 12:10 AM
I gathered that would be the case with the SB4's and surrounding area, is there any good material left under all that crap?
Old 21st July 2012, 12:14 AM
I will hack into the mule and take a piccie.
Old 21st July 2012, 08:29 AM
Old 3rd August 2012, 09:53 AM
PorkChop PorkChop is offline
Robo, do you have some dimensions please (particularly the distance between the prop flange to the centre of the output flanges)? I'll compare it to my MX5 diff.
The BMW units can come in very long ratios (i.e. longer than 3:1), which may be very handy for BECs...
Old 3rd August 2012, 02:13 PM
Its 300mm face of prop flange to driveshaft flange center line. They come in small,medium and large case the one I have is large case. You can get a 2.81 ratio in a medium case. There is lsd options on all of them.
http://www.bokchoys.com/differential/GearRatios.htm
Old 3rd August 2012, 09:03 PM
Yep, I know Cheers for the measurement. I wonder how much smaller the medium case is than the large case...
