![]() I have this bearing: SLFL25 LDK Pressed Steel Flange Bearing
![]() I will use it to mount my column shaft to the bulkhead. I know than many people have used it but i am looking for pictures to see how exactly you have mounted it. If i mount it on the CP16 plate, i will have to open a large hole (56mm diameter) which is not the easiest job to do, unless i order again the CP16 from the laser shop. Any ideas? |
Thread Tools | |
Display Modes | |
