Old 14th November 2012, 09:43 PM
tkpm tkpm is offline
Default Help with Relays
Hi,
Needs some help with Relays.
When i moved my build from a workshop to my garage at home, my sierra fusebox went missing along with all the relays.
I'm getting confused as to what i need, 4 pin / 5 pin and amps etc.
Here is a list of relays that i need to sort out.
Main Beam Relay -
Dip Beam Relay -
Fuel Pump Relay -
Ignition Relay (not sure if i need this one) -
Thanks in advance
Terry
Old 14th November 2012, 10:47 PM
I didn't use a single 5-pin relay in my wiring (I mostly left the Sierra relay box intact) and just one normally closed relay for the ECU's fan control.
Have you found David Murray's excellent wiring diagram? It was all the inspiration I needed to wire my car. All the fuses, wires and relays are listed with their ratings, as well as the pin numbers for the Sierra column switches: http://www.haynes.co.uk/forums/showthread.php?t=4763
Old 14th November 2012, 11:08 PM
I'd forgot about Daves wiring diagram, Thanks for reminding me Alga.
Terry
Old 18th November 2012, 02:49 AM
I have a fuse box complete with relays I'm not useing give me a ring
