Old 31st August 2008, 04:30 PM
Default Building to the SVA Manual
As i am nearing the completion if the chassis frame i thought it was time to start thinking about sva so that i can can make sure everything complies as i build rather than changing loads of things at the end
i found this electronic version of the manual online. it says draft on it though. could anyone tell me if it is good enough to work from or should i just pay out for the paper copy?
http://fp.topcateng.plus.com/Garage/...nual_draft.pdf
