Old 9th March 2011, 06:31 PM
jmh jmh is offline
Default zetec flywheel from a mk1 focus
Hi all,
still looking at flywheels for a zetec to type 9 setup. Have found loads of flywheels for the 1.8 zetec focus. So my question is whether or not this flywheel will work?
thanks in advance,
Jonathan
Old 9th March 2011, 07:34 PM
mark mark is offline
Yes that should be ok, im using a 1.8flywheel/mk1 mondeo clutch kit/ct133 release bearing and its fine
No issues whatsoever simple bolt together stuff
Old 9th March 2011, 08:35 PM
jmh jmh is offline
Cheers,
I already have most of the rest of it, just trying to make sure I get the right flywheel.
Then I can get it all together.
Old 9th March 2011, 08:50 PM
Mine was from a silvertop to be exact, i was going to reuse the cvh one from my old set up as its lighter, but i went for the zetec flywheel in the end so i didnt have to mount a trigger wheel on the bottom pulley for megajolt
