Old 8th May 2011, 03:20 PM
davylock davylock is offline
Question Oval Steering Column Mount on Sierra
Anybody have any idea what bolts/fixings are used for mounting the Oval Alloy Upper Steering Column bracket to the CP15 Plates. The reason I ask is the elongated holes on the CP15 plates are drilled to M13, but the Oval Bracket holes are wider ( 17mm ? ). Is there need for inserts of some kind which I'm missing. In the sierra manual it just shows two nuts holding the column.
Its a non adjustable column off an '88 Sapphire by the way, Dave.
Old 8th May 2011, 04:12 PM
SeriesLandy's Avatar
Took me a while to understand where you meant. I was wondering the same thing and was thinking of getting someone to turn me up 2x tophat type inserts for the bolts to pass through. If that makes sense.
I don't know if they are really needed but would put my mind at rest.
Old 8th May 2011, 05:04 PM
Steve, that's the way I think I'll go as well, & get my mate to turn a couple up on his lathe. thanks anyway, Dave.
Old 8th May 2011, 06:52 PM
I have been wondering tooooo.
Old 8th May 2011, 08:17 PM
What did it have on the sierra, it was soooo long ago I stripped mine I can't remember what it looked like.
Old 8th May 2011, 09:06 PM
It looks like it was just two 17mm nuts that bolted on to fixed studs underneath the fascia as far as I can make out, I never had a donor vehicle, I've just bought parts as I've gone along, Dave.
Old 8th May 2011, 09:44 PM
I should know.. Taken many appart and put them back together....
Will have to have a look at one of the cars and find out.
I considerd just making some ruber bushes.
Old 9th May 2011, 01:18 AM
Looking in the sierra manual there is definatley something in there,possibly rubber? although the manual doesnt even mention it or show an exploded view.
Old 9th May 2011, 06:19 AM
snapper snapper is offline
Exclamation
One test at IVA is to grasp the steering wheel and pull, push, forward, backwards, side to side. This test that the mountings are secure.
I found some steel tube of the right outside diameter to fit the steering column mounts, drilled to take the bolts and bolted it all together with wide washers.
Solid it is.
Old 9th May 2011, 08:45 AM
Smile steering column oval
So the general opinion seems to be that as long as it is some kind of hard rubber / steel bush it should be ok. With it being steering, I just wanted to be sure and I think you've all answered that OK, cheers, Dave.
