Old 6th September 2012, 09:07 PM
Default Sierra track rod ends position
Hi everyone,
Are my track rod ends in the right position: inserted into the uprights from bellow as on the donor (Sierra donor - Sierra front uprights - Sierra track rod ends)?
Thank you.
Old 6th September 2012, 09:11 PM
yes
that is correct.
Old 6th September 2012, 09:17 PM
Cool! Thanks a lot TT
Old 7th September 2012, 02:49 PM
TT, do you know what's the function of the the triangular protrusion on the rod end? Even with 15" rims it's pretty close to the wheel.
Old 8th September 2012, 11:36 AM
Grind it off Albert,it would fail the radius test here.
Old 8th September 2012, 02:26 PM
a sierra TRE has off set when viewed from above the track rod should be offset to the rear of the car it alows extra clearance iirc
my aftermarket ones have L & R forged in and thay also match up
the tang bits look like there there to aid mass manifacture so forged blanks can be mounted/clamped quickly for machining
Old 8th September 2012, 07:27 PM
Seen TRE's put on the wrong sides on a Volvo I tested,carves inner rims to bits.
