Old 8th September 2012, 12:34 PM
DaveyB DaveyB is offline
Default Radiator
Hi, wonder if anyone can reccomend what type of radiator to use in conjunction with a ford pinto engine if there is a particular current model car that has a suitable rad.
Thanks
DaveyB
Old 8th September 2012, 01:39 PM
Best bets are a Polo rad or a clio rad.Both can be found new on ebay for about 25-30quid.
Old 8th September 2012, 02:28 PM
or the small merc 190E 1.8-2.3 petrol manual -93
Old 8th September 2012, 10:18 PM
The "Polo rad" is the one from a 1983-1990 VW Polo 1.0, core dimensions 322x380 mm, this one: http://www.partsbase.net/part/ava-vw2038 Fits under Haynes nosecones with ample room to spare, seems to be sufficient for 2 litre engines.
Old 8th September 2012, 10:20 PM
You could also take the one which is 5 cm wider, it fits under the Saturn nosecone fine, but there might be clearance problems for the lower outlet with the front frame.
