Old 17th November 2012, 03:29 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Default Cp3/4 positioning
I am about to start working on positioning cp3/4 is there anything I need to be aware of or pay particular attention to when making up and positioning them
Many thanks
Old 17th November 2012, 03:48 PM
Lay them side by side and mark them with a perminant pen 'front' 'right' and 'left' on both plates, make sure that they are handed before you even think of welding them! I often make 2 right handed plates and have to start again on a left handed one and thats after making 50+ of the sodding things.
Old 17th November 2012, 04:06 PM
I had to remove the first ones I did because I was not happy with the welds of the nuts and the shock bracket.
It was a good thing, as I figured out the old ones were not completely lined up with the lower shock mount on the rear upright. So when I tacked the new ones, I used the shock absorber to line them up perfectly.
Also I drilled RB1 and RB2 at the same time as CP3/CP4 to be sure to get exactly the same bolt pattern.
Last, I chose to put M10 nuts and not M8, so the roll bar is fitted with M10 bolts. I trust this more than M8, I don't know if I'm right or wrong, but it is not a big deal anyway.
Good luck
PS: I just quickly put the pictures and a few comments on my blog a few minutes ago, if you want to have a look:
http://vouchtroadster.blogspot.com/2...-2nd-ones.html
Old 17th November 2012, 08:59 PM
Top tip there Phil, there's too many ways to position them wrong!
Old 19th November 2012, 06:11 PM
vmax1974's Avatar
Top tips thank you gents
