Old 14th December 2009, 04:52 PM
Rik178m Rik178m is offline
Default Tacking the chassis
Is a stick welder ok to use for tacking the chassis? Obviously not suitable to fully weld it I know.
Old 14th December 2009, 05:12 PM
Tatey's Avatar
Tatey Tatey is offline
The tack is just there to hold the pieces together to stop try and prevent any welding distortion, so i personally would say yes it will be ok, but you'll need to make sure any slag is removed before you fully weld with a MIG or TIG, otherwise you'll get impurities in the weld.
Old 14th December 2009, 05:17 PM
mark mark is offline
Yes this will be fine for tacking up with and even welding the chassis with if you are competent using it
It is just much easier and quicker to use a mig
As Tatey says make sure you remove all traces of slag from your tacks before welding over them
Old 14th December 2009, 06:14 PM
As above really.
Go for it but don't get too keen with the tacks....... You'll soon find a hole where you didn't want one
Old 16th December 2009, 03:11 PM
Yep wouldn't say I'm the handiest with a stick welder but just thinking about the options. Thanks
Old 16th December 2009, 08:57 PM
Enoch Enoch is offline
I'm doing mine with arc. You get better penetration with arc. Don't turn the current up too far and you won't burn through.
