Old 2nd September 2010, 02:12 PM
MikeB MikeB is offline
Default Mx-5
Not sure what engine I want in my new build but My brother has a rotting 1.6 mx-5 uk spec on a G plate on his drive, its' done high mileage but is free to me if I want any of it.
What if anything could I use. I don't intent to buy a complete sierra donor rather amass the right bits over time.
Was thinking the engine and gearbox as it will be non cat IVA and have a feeling the ecu and inlet will be an easy swap into the haynes.
Drive it for a bit and either upgrade to a 1.8 mx-5 engine or go zetec etc.
is the gearbox a similar size to the the type 9? Anyone used a mx5 steering column. I'll proberbly keep the back end sierra and the front uprigts to keep things simple.
Old 2nd September 2010, 05:10 PM
TQ_uk TQ_uk is offline
There's a few people building MX5 based roadsters (ie using uprights & diff's) so I'd be tempted to use the whole lot & forget the Sierra.
Rumour is there's going to be an updated version of the book with this kind of info in....?
If you're not interested I'll take the whole car off your hands
EDIT: Here you go:
http://www.mx5-locost.co.uk/
Its Airhead on here (I think!)
Old 2nd September 2010, 07:50 PM
les g les g is offline
contact john at 3ge
i think he will be able to help you with this
he is up to speed with this install
cheers les g
Old 2nd September 2010, 10:47 PM
Airhead's Avatar
Airhead Airhead is offline
Yep that's mine - I need to update my build thread as the rear dif is now mounted and I am about to drop the motor into the frame to test fit and get the motor/gearbox mounts sorted the only component not directly usable off the MX5 is the steering rack as it is about 150mm too long - I am using the Ford offering I think.
Matt
Ther's no place like 127.0.0.1
My build diary. http://www.mx5-locost.co.uk
Old 3rd September 2010, 10:00 AM
Thanks all.
It looks like you need to widen the tranny tunnel a bit.
I think I was looking at it from a cheap engine and gearbox for IVA perspective. Rather than a complete donor
