Old 18th October 2010, 10:03 PM
tkpm tkpm is offline
Default Bike Carbs on a 2L Pinto
Hi guys,
In need of some info on which bike carbs are best suited to a 2l sohc Pinto (1988), seen a lot post with cbr600, zx900, etc.
But know i'm as which are the best to use.
Thanks in advanace for your surgestions
Terry
Old 19th October 2010, 09:24 AM
kj71 kj71 is offline
I have zzr1100's on mine
Old 19th October 2010, 11:59 AM
Tony Tony is offline
whichever are the cheapest on ebay
Old 19th October 2010, 12:20 PM
davidimurray's Avatar
Look at the HP rating of the bike you are planning to uses. Generally they are all pretty much the same excpet for the diameter. I am going to use ZX6R carbs on my 1.8 pinto as they should be good for around 110hp. As strange as it sounds go for the smallest you can for the hp you want. The bigger you go the worse the throttle response will be. While that doesn't really matter for a track car it makes a big difference on the road for the sake of 1 or 2 bhp.
Old 19th October 2010, 12:47 PM
I'm using ZX6r on a 2.0l Zetec Terry, running at 170hp - they don't restrict the airflow and the throttle response is fantastic. The only thing is to get them set up professionally, for the sake of £80 its well worth it.
All the Best....AndyH
Old 19th October 2010, 06:07 PM
mark mark is offline
Im on zx6r carbs also as spud is, they are very responsive
Whichever ones you decide on try and get some with a throttle position sensor on then if you want to set up with megajolt you can run a 3d map rather than 2d
