Old 17th July 2011, 12:45 PM
Jimmyd Jimmyd is offline
Default Fitting 4pt Harness
Can anyone who has fitted a 4pt harness just confirm if the top mounts should swivel? I've a set of TRS harness' and note that lap belt mounts have a "bush" to swivel on but the shoulder mounts are slightly smaller and appear to mount solid when bolt in.
J
Old 17th July 2011, 02:56 PM
They should swivel as far as I'm aware, certainly mine do.
Adrian
My Build Pictures:
Old 17th July 2011, 04:14 PM
gus's Avatar
gus gus is offline
I used TRS harness and no the top brackets do not swivel .
Old 17th July 2011, 06:55 PM
Seat belts usually are fitted with a stepped collar and a wavy washer to allow them to swivel but still be secure.
Old 19th July 2011, 06:36 AM
not sure about trs ones but shuold be as above for most belts
