Old 1st December 2012, 03:29 PM
jps jps is offline
Default Which p-clips?
Just trying to work out which p-clips to buy on e-Bay for my brake lines. Had assumed all brake lines would be metal, but loads of them are nylon. Are they any good? Or do I need the (expensive!) steel ones that are lined with rubber...?
Old 1st December 2012, 07:19 PM
You can make a really good job of a p clip with a strip of ali 10mm wide with some innertube rubber stuck to it. Just form it round a piece of rod slightly smaller than the pipe you need a clip for. leave the tails long untill your happy with them then drill the fixing hole. trim the tails last. Take your time with it in a vice and they turn out top notch.Its worth glueing up a load of it because there will be so many things that need clipping that are all different diameters.
Old 1st December 2012, 07:57 PM
Bob, were you a Blue Peter fan by any chance?
Old 1st December 2012, 08:57 PM
FUGGIT
Just for that I am going to do a how to make a p clip post. If you thought my pipe engineering post was bad watch this space
Old 1st December 2012, 09:05 PM
FUGGIT
ROTF PMSL!
Look forward to it more tip and tricks learned, can it be done in SS ?
Old 7th December 2012, 01:58 PM
jps jps is offline
Decided to throw caution (and £4.80) to the wind and bought a bag of 100 nylon p-clips in 4.8mm. Anyone else used these to secure their brake lines?
