Old 5th August 2009, 10:20 PM
davidimurray's Avatar
Default What have you done to your donor parts?
Out of interest - what work have you done to your donor engine/transmission over the mods required for fitting.
I'm hoping to swap the cambelt on mine, give it a good check over, then a degrease and a full repaint of all the donor bits. I like the idea of having a nice shiny engine under the bonnet - also gives my finances a break for a while
Old 5th August 2009, 10:27 PM
likewise, painted engine & gearbox, changed plugs, cambelt, oil filter, sump gasket, rocker gasket, fuel pump & thermostat gaskets, inlet & exhaust gaskets, rotor arm & plug leads, oh & a new clutch , new flywheel bolts, new alternator belt, thats about it apart from new oil for engine/gearbox & diff.
cleaned & painted uprights, driveshafts, brake drums etc.
phew thats quite a bit when i write it down???
Old 5th August 2009, 10:35 PM
Cheer guys. Sounds like you've been busy Andy. Out of interest what paint is everyone using - reading around the net there seems to be lots of opinions - one of the most common being that engine paint is rubbish! Oh and then there is the question of colour
Old 5th August 2009, 11:06 PM
black smooth hammerite for the block & sump & ali paint for the rocker cover, gearbox bellhousing in black hammerite & ali paint for the "box",
not too bling bling but makes it look clean & tidy
Old 8th August 2009, 02:13 PM
Sam Sam is offline
The most important thing that needs to be done correctly. And you can quote me because I am an expert in this field. The paint HAS to be and no other alternative is acceptable !! It has to be BLUE !! Any flack for this statement can be directed elsewhere because I am right ! NO !!! Dont even bother with the reply button I AM right !!!
Wheres my beer !
Old 8th August 2009, 08:01 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
I would have to agree all my engines for the last 25 years have been blue, except of course the mini ones green and standard triumph ones black lmfao
Ray
Old 8th August 2009, 09:11 PM
Wheres my beer !
Hmmmm...............Feeling a bit feisty today are we
I know you said that you are an expert in the field.........But how are you with car engines
One thing for sure, it seems that only the Blue engine paint appears to be up to the job these days
The Red & Black that I have tried over the last couple of years, for want of better words, have been crap !!??
