			 I wonder if any of you with your engine/box and rear end in
			can tell me the length of their propshaft. From the diff flange to the face of the box input shaft. I asked Ash, he said he thinks his is 644mm. As you may or may not know, I have modded the rear end to make the wheel base 25mm longer. Now the engine is in I can order the new prop. Measured it yesterday....635mm !!!!!! Was expecting 670mm, not sure what's going on. Everything else should be to the book. So thought I would ask what lengths other people have. Cheers
	. . David. Heaven, Warm days and Cool rides
			 Just measured Handy's (Oooerrr misses), and his is 600mm flange to flange mine was about the same from memory. It all depends how far back you site the engine, mine was as far back as poss.
			So 600 + 25mm would be a close match. Regards....AndyH
	Haynes Roadster / Saturn GRP Bodywork. Now available direct through http://www.gillhamonline.co.uk/ or contact me direct on andrew.hugill@ntlworld.com Regards..........AndyH  |
			 humm that's strange.  just measured it again ad its defiantly 644mm
	i got it back as far as i possibly could. in fact the first time i put it in the clutch fork touched the tunnel so i had to shift it forward a bit.  |
     But I had finished painting the chassis and had to do some proper mucking about to shift the engine forward so the Type 9 reverse switch is slight in front of an upright in the transmission tunnel. |
 Everyone's is going to be slightly different...... ![]()
			 Cheers for the input guys.
			Using the reverse switch and the upright as a set point. My switch is a goosd bit behind the upright. So poss that's where the shortness came from. Still got clearence for the clutch arm......just! Couple of pics. The reverse switch ain't fitted but you can see the ole. Also a pic of the phlenum through the bonnet. No reason just thought I'd post it. ![]() ![]() ![]()
