Old 25th October 2010, 10:53 PM
misty misty is offline
Default fire protection for the petrol tank
has anyone any idea of how i could protect the tank from catching fire from whatever reason. i just think that if the tank goes or catches fire the thought of a little protection around it would give some piece of mind
Old 26th October 2010, 08:54 AM
Locky Locky is offline
Could wrap it in a fire blanket, but i think if the tank went up i would leave the car and leg it. i cant see any reason why a tank would go up unless it leaked or gave off fumes.
If it has breasts or wheels it will give you problems.
Planning Stage
Old 26th October 2010, 11:00 AM
Fire is more likly to start in the engine bay and work it's way backwards, even so the tank would have to be leaking badly to give of enough vapour ( petrol fluid is not flamable ) to cause an explosion.
If your realy worried then a plumbed extinguisher with automatic release is the best option.
Old 29th October 2010, 01:36 AM
tex tex is offline
1.best bet is to make sure your fittings are good - well made.
2.make sure the tank has some form of collision defence - ie brace bars around it if possible
3. you can add foam to the inside to soak up the fuel - if it did get split the foam reduces the speed the fuel comes out - reducing the chances of explosion etc
4. you could get a plumbed extinguisher fitted - a hand held one is ok but it MUST be fitted in a bracket securely
5. finally make sure you can get out in 10 seconds flat (if i remember rightly the time set for drag drivers to get out saw it on the tv at bonnville or summink - might be wrong tho - lol )
